*nctlayers()
Creates an nctlayer in HMASCII format.
*nctlayers() (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the nctlayer.
- name
- The name of the nctlayer.
- color
- The color of the nctlayer. Valid values are 1-64.
To create an nctlayer with ID 100, name "my-entity", and color 1:
*nctlayers(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
