*modelcheckcorrections()
Creates a model check correction in HMASCII format.
*modelcheckcorrections (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the model check correction.
- name
- The name of the model check correction.
- color
- The color of the model check correction. Valid values are 1-64.
To create a model check corrections with ID 100, name "my-entity", and color 1:
*modelcheckcorrections(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
