*enginefiles()
Creates an enginefile in HMASCII format.
*enginefiles (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the enginefile.
- name
- The name of the enginefile.
- color
- The color of the enginefile. Valid values are 1-64.
To create an enginefile with ID 100, name "my-entity", and color 1:
*enginefile(100,"my-entity",1)
Incorrect usage results in an import error.
