*sketches()
Creates a sketch in HMASCII format.
*sketches (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the sketch.
name
The name of the sketch.
color
The color of the sketch. Valid values are 1-64.
To create a sketch with ID 100, name "my-entity", and color 1:
*sketches(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
