イベント固有のレポート
さまざまな車両イベントでさまざまなプロットが出力されます。プロットは、特定のイベントに重要なメトリックに基づいて選択されます。
このレポートにアクセスするには、ブラウザで各イベントのコンテキストメニューを使用するか、メニュー項目での順に選択します。
以下のトピックでは、イベントごとのプロットをページ単位で一覧しています。
Constant Radiusイベント
- Steering Input and Accelerations
- Steering Wheel Angle vs. Time
- Steering Wheel Torque vs. Time
- Lateral Acceleration vs. Time
- Longitudinal Acceleration vs. Time
- Vehicle Velocities
- Yaw Rate vs. Time
- Longitudinal Velocity vs. Time
- Lateral Velocity vs. Time
- Vehicle Slip Angles
- Front Sideslip Angle vs. Time
- Rear Sideslip Angle vs. Time
- CG Sideslip Angle vs. Time
- Roll Angle
- Roll Angle vs. Time
- Steer/Suspension Travel
- Front Steer Angle vs. Time
- Rear Steer Angle vs. Time
- Front Suspension Travel-left vs. Time
- Front Suspension Travel-right vs. Time
- Rear Suspension Travel-left vs. Time
- Rear Suspension Travel-right vs. Time
- Steering, roll and torque
- Steering Wheel Angle vs. Lateral Acceleration
- Steering Wheel Torque vs. Lateral Acceleration
- Roll Angle vs. Lateral Acceleration
- Vehicle Path
- Vehicle Slip vs. Acceleration
- Front Axle Sideslip vs. Lateral Acceleration
- Rear Axle Sideslip vs. Lateral Acceleration
- CG Sideslip Angle vs. Lateral Acceleration
- Steering Wheel Angle vs. Vehicle Sideslip Angle
- Tire Lateral Slip
- Left Front Tire Lateral Slip vs. Time
- Right Front Tire Lateral Slip vs. Time
- Left Rear Tire Lateral Slip vs. Time
- Right Rear Tire Lateral Slip vs. Time
- Vertical Tire Forces
- Left Front Tire Vertical Force vs. Time
- Right Front Tire Vertical Force vs. Time
- Left Rear Tire Vertical Force vs. Time
- Right Rear Tire Vertical Force vs. Time
- Lateral Tire Forces
- Left Front Tire Lateral Force vs. Time
- Right Front Tire Lateral Force vs. Time
- Left Rear Tire Lateral Force vs. Time
- Right Rear Tire Lateral Force vs. Time
- Longitudinal Tire Forces
- Left Front Tire Longitudinal Force vs. Time
- Right Front Tire Longitudinal Force vs. Time
- Left Rear Tire Longitudinal Force vs. Time
- Right Rear Tire Longitudinal Force vs. Time
- Wheel Aligning Torques
- Left Front Tire Aligning Torque vs. Time
- Right Front Tire Aligning Torque vs. Time
- Left Rear Tire Aligning Torque vs. Time
- Right Rear Tire Aligning Torque vs. Time
- Vertical Tire Forces vs. Lateral Acceleration
- Left Front Tire Vertical Force vs. Lateral Acceleration
- Right Front Tire Vertical Force vs. Lateral Acceleration
- Left Rear Tire Vertical Force vs. Lateral Acceleration
- Right Rear Tire Vertical Force vs. Lateral Acceleration
- Lateral Load Transfer
- Front Lateral Load Transfer vs. Lateral Acceleration
- Rear Lateral Load Transfer vs. Lateral Acceleration
Single Lane Changeイベント
- Yaw Rate vs. Time
- Roll Angle
- Vehicle CG Displacement
- Vehicle CG Disp(Y) vs. Vehicle CG Disp(X)
Double Lane Changeイベント
- Yaw Rate vs. Time
- Roll Angle
Swept Sineイベント
- Swept Sine: SWA, Lateral Acceleration, Yaw Rate, Roll
- Yaw Rate vs. Time
- Frequency Plots, Magnitude and Phase
- Ay/Steering Wheel Angle Magnitude
- Ay/Steering Wheel Angle Phase
- Yaw Rate/Steering Wheel Angle Magnitude
- Yaw Rate/Steering Wheel Angle Phase
- Roll/Ay Magnitude
- Roll/Ay Phase
直線加速イベント
- Tire Longitudinal Slip
- Left Front Tire Longitudinal Slip vs. Time
- Right Front Tire Longitudinal Slip vs. Time
- Left Rear Tire Longitudinal Slip vs. Time
- Right Rear Tire Longitudinal Slip vs. Time
- Vertical Longitudinal Acceleration and Velocity
- Suspension Travel
- Steering Wheel Angle and Torque
- Drive Torque vs. Time
- Pitch, Front Lift and Rear Squat
- Pitch vs. Longitudinal Acceleration
- Front Lift vs. Longitudinal Acceleration
- Rear Squat vs. Longitudinal Acceleration
- Vehicle Tire Forces
- Left Front Tire Vertical Force vs. Longitudinal Acceleration
- Right Front Tire Vertical Force vs. Longitudinal Acceleration
- Left Rear Tire Vertical Force vs. Longitudinal Acceleration
- Right Rear Tire Vertical Force vs. Longitudinal Acceleration
- Axle Loads
- Front Axle Load vs. Longitudinal Acceleration
- Rear Axle Load vs. Longitudinal Acceleration
- 横方向の加速度
- Left Load Transfer vs. Longitudinal Acceleration
- Right Load Transfer vs. Longitudinal Acceleration
Straight Line Brakingイベント
- Vertical Longitudinal Deceleration and Velocity
- Longitudinal Deceleration vs. Time
- Suspension Travel
- Brake Torque
- Left Front Brake Torque vs. Time
- Right Front Brake Torque vs. Time
- Left Rear Brake Torque vs. Time
- Right Rear Brake Torque vs. Time
- Pitch, Front Drive and Rear Lift
- Pitch vs. Longitudinal Deceleration
- Front Drive vs. Vehicle Deceleration
- Rear Lift vs. Vehicle Deceleration
- Left Front Tire Vertical Force vs. Vehicle Deceleration
- Right Front Tire Vertical Force vs. Vehicle Deceleration
- Left Rear Tire Vertical Force vs. Vehicle Deceleration
- Right Rear Tire Vertical Force vs. Vehicle Deceleration
- Axle Loads
- Front Axle Load vs. Vehicle Deceleration
- Rear Axle Load vs. Vehicle Deceleration
- Longitudinal Load Transfer
- Left Load Transfer vs. Longitudinal Deceleration
- Right Load Transfer vs. Longitudinal Deceleration
Sinusoidal Steeringイベント
- Yaw Rate vs. Time
- Vehicle CG Displacement vs. Time
Brake In Turnイベント
- Axle Loads
- Front Axle Load vs. Lateral Acceleration
- Rear Axle Load vs. Lateral Acceleration
- Front Load Transfer vs. Lateral Acceleration
- Rear Load Transfer vs. Lateral Acceleration
J Turnイベント
- Tire Lateral Slip
- Axle Loads
- Steering, Roll and Torque
- Yaw Rate vs. Lateral Acceleration
- Sideslip
- CG Sideslip Angle
- Understeer vs. Lateral Acceleration
Throttle-off Corneringイベント
- Yaw Rate vs. Time
Swept Steerイベント
- Yaw Rate vs. Time
- Roll Angle
- Vehicle Path
- Tire Lateral Slip
Pulse Steerイベント
- Yaw Rate and Vehicle CG Displacement
- Yaw Rate vs. Time
- Steering Input
Throttle-off Turn-inイベント
- Tire Lateral Slip
- Axle Loads
- Engine Torque vs. Time
Step Steerイベント
- Yaw Rate vs. Time
- Steering Wheel, Torque and Roll
Power Off in a Straight Lineイベント
- Axle Loads
- Front Drive vs. Longitudinal Acceleration
- Rear Lift vs. Longitudinal Acceleration
n-Post Shakerイベント
- 信号タイプ = 加速度 / 変位
- イベントのアニメーション
- 車体加速度
- ハンドル加速度
- ホイール抑止力(ホイール数と同じ数のページ)
- アクチュエーター変位(アクチュエーター数と同じ数のページ)
- アクチュエーター力X/Y/Z(アクチュエーター数と同じ数のページ)
- 信号タイプ = 力 / モーメント
- イベントのアニメーション
- 車体加速度
- ハンドル加速度
- アクチュエーター力 / モーメント
安定性解析
- 解析モード = 線形
- イベントのアニメーション
- モデルに関してMotionSolveから報告される固有値(.eigファイル)
- 解析モード = パルスの適用 / 外乱の適用
- イベントのアニメーション
- 適用されたパルスまたは外乱
- 力の大きさ
- トルクの大きさ
- ハンドル角
- 実舵角対時間
- 実舵角のFFTの大きさ
- 車両変位
- ロール角対時間
- ロール角のFFTの大きさ
- ヨー角対時間
- ヨー角のFFTの大きさ
