hm_attributesolverarrayvalues
Returns the solver code and all values for a 1D array attribute on an entity.
hm_attributesolverarrayvalues entity_type entity_name_or_id search_type attribute_name_or_id ?extend_search?
HyperMesh Tcl Query Command
Returns the solver code and all values for a 1D array attribute on an entity. The command first searches to find the specified attribute for the current template. If the attribute is not found for the current template, the search can be extended to search all attributes assigned to the entity. If the attribute does not exist on the entity, an error is returned.
- entity_type
- The type of entity to query.
- entity_name_or_id
- The name or ID of the entity.
- search_type
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
- attribute_name_or_id
- The name or ID of the attribute to query. If a name is specified, the attribute must exist in the current template.
- extend_search
- By default, the attribute will only be searched for the current template. However, the search can be extended to search all attributes assigned to the entity. If the attribute is specified by name, this argument is ignored and only the current template is considered. Valid values are:
To get the solver code and all values of the 1D array for the attribute with name Example on material 6, considering only the current template:
hm_attributesolverarrayvalues material 6 -byid Example
or
hm_attributesolverarrayvalues material 6 -byid Example 0
To get the solver code and all values of the 1D array for the attribute with ID 100 on material 6, considering all attributes:
hm_attributesolverarrayvalues material 6 -byid 100 1
# Handle error
