hm_checkproximity
Checks proximity between elements/components.
hm_checkproximity entity_type mark_id max_proximity ?mode? ?check_side? ?proximity_scheme? ?proximity_by_edge? ?min_angle_limit? ?max_angle_limit?
HyperMesh Tcl Query Command
Checks proximity between input entities and returns list of entities within the specified proximity. The output depends on the mode argument as defined below.
- entity_type
- The type of entity to check. Valid values are elems and comps (only elems in comps are considered).
- mark_id
- The ID of the mark containing the entities to check. Valid values are 1 and 2.
- max_proximity
The maximum distance beyond which an entity is not considered.
- mode
- 1 - Global proximity (default)
- check_side
- 1 - Check both sides of elements
- proximity_scheme
- 0 - Checks basic proximity along a ray from the element center along the normal direction.
- proximity_by_edge
- 0 - Ignores proximity for nearby edges (default behavior if not specified).
- min_angle_limit
- If the angle between the proximate element pairs is less than this value, such pairs are not reported.
- max_angle_limit
- If the angle between the proximate element pairs is greater than this value, such pairs are not reported.
*createmark comps 1 all
hm_checkproximity comps 1 2.5
{{201 200 199 198 197 196 195 194 225 224 223 222 221 220 219 218} {221 219 220 218 225 223 224 222 197 195 196 194 201 199 200 198}}Errors
# Handle error
}Version History
13.0.110
2019 - Added new optional arguments proximity_scheme and proximity_by_edge. Changed default behavior of API to use proximity_scheme value 1.
2019.1 - Added new optional arguments min_angle_limit and max_angle_limit.
