hm_exportdummytargetpointstocsv
Exports the marked design points with ‘TargetPoint’ configuration to a CSV file.
hm_exportdummytargetpointstocsv mark_id file_path
HyperMesh Tcl Query Command
- the name of the design point,
- X/Y/Z,
- the corresponding test lab measurement data,
- the allowed negative deviation,
- the allowed positive deviation,
- the coordinate value for the measurement node located on the dummy,
- the signed difference between the CAE position and the test data.
If the specified CSV file already exists, it will be overwritten.
- mark_id
- The ID of the mark containing the design points to be exported. Valid values are 1 and 2.
- file_path
- The path to the CSV file.
*createmark designpoints 1 1 2 3
hm_exportdummytargetpointstocsv 1 "C:/temp/targetpoints.csv" Errors
# Handle error
}Version History
2022
