hm_exportoptimizationcards
Exports a Radioss optimization file.
hm_exportoptimizationcards type filename export_template
HyperMesh Tcl Query Command
- type
- The type of file to write:
- filename
- The full path and filename of the output optimization file (*.radopt). Paths with spaces must be enclosed in quotes.
- export_template
- The full path and filename of the optimization export template. Paths with spaces must be enclosed in quotes.
Examples
To export the optimization file, deriving the name from the model file C:/my_files/model_0000.rad:
hm_exportoptimizationcards 1 "C:/my_files/model_0000.rad" "[hm_info -appinfo SPECIFIEDPATH TEMPLATES_DIR]/feoutput/radioss/optientities.blk"
# Handle error
Version History
2019
