hm_wadlinesgetgridpoints
Returns coordinate data defining WAD grid points.
hm_wadlinesgetgridpoints wad_child_min wad_child_max wad_adult_min wad_adult_max side_tolerance ?protocol_method? ?protcol_version? ?grid_spacing? ?vertical_spacing?
HyperMesh Tcl Query Command
Child -6 3 1.45816988887E+003 -600 8.59794186814E+002 Middle -1 6 1.75816988887E+003 -100 9.73484336137E+002 Adult -5 9 2.05816988887E+003 -500 1.03367256770E+003Inputs
- wad_child_min
- The WAD line where child impact points begin.
- wad_child_max
- The WAD line where child impact points end.
- wad_adult_min
- The WAD line where adult impact points begin.
- wad_adult_max
- The WAD line where adult impact points end.
- side_tolerance
- GTR - No impact points are found within this distance of the side reference lines.
- protocol_method
- The method to use for measuring the side_tolerance distance.
- protocol_version
- Used for Euro NCAP protocol, 7.0 (default if not specified), 8.0 or 8.2.
- grid_spacing
- The spacing between the impact points, default 100.0.
- vertical_spacing
- For GTR, it is the spacing between 2 wadlines on which impact points need to be created, default 100.0.
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
*createmark elems 1 "by collector" wipers
hm_wadlinessetwipers elems 1 0 1
hm_wadlinesgetreferenceline 0
hm_wadlinesgetreferenceline 1
hm_wadlinesgetreferenceline 2
hm_wadlinesgetreferenceline 3
hm_wadlinesgetreferenceline 4
hm_wadlinesgetreferenceline 5
hm_wadlinesgetreferenceline 6
hm_wadlinesgetreferenceline 7
hm_wadlinesgetwadline 1000.0
hm_wadlinesgetwadline 1500.0
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadline 2100.0
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
hm_wadlinesendErrors
# Handle error
}Version History
12.0.110
2020 - Added new optional arguments grid_spacing and vertical_spacing. Added new protocol_method value 4.
