hm_getnodeinitialcoords
Returns the node position on the initial associated geometry.
hm_getnodeinitialcoords node_id
HyperMesh Tcl Query Command
Returns the node position coordinates on the initial associated geometry. If a node does not have any initial geometry association, the command returns an empty list.
- node_id
- The ID of the node.
hm_getnodeinitialcoords 1Errors
# Handle error
}Version History
2021.2
