hm_getsketchdata
Queries the information about the entities present in the sketch.
hm_getsketchdata <select_type>=<selection> entitytype=<value> sketchdata=<value>
HyperMesh Tcl Query Command
Queries the information about the entities present in the sketch data.
- <select_type>=<selection>
- The entity or entities that are to be queried. There are several ways to provide the
entities to be queried. Only one option can be used at a time:
- id=<sketch_id>
- The ID of the sketch entity.
- name=<sketch_name>
- The name of the sketch entity.
- entitytype=<value>
- The type of queried entity present in the sketch.
- sketchdata=<value>
- The queried sketch entity data name.
*hm_getsketchdata id=1 entitytype=point sketchdata=entitylist
# Handle error
Version History
2021.2
