hm_collisiongetcomponentpair
Returns the component IDs of a collision pair.
hm_collisiongetcomponentpair collision_type component_index ?include_ignored?
HyperMesh Tcl Query Command
Returns the component IDs of a collision pair. This must be preceded by a call to relevant hm_collision* commands to generate the collision data. In addition, the pair_results flag to hm_collisioncheck must be set to 1.
For each collision type there is a list of pairs of colliding components. For each colliding component pair, there is a list of colliding entity pairs. Thus, their is a hierarchy of data with the tree looking like this:
collision type -> component pairs -> entity pairs
The data is therefore accessed as:
  1. Get the number of colliding component pairs.
  2. Get the component IDs for each component pair.
  3. Get the number of intersected entities for each component pair.
  4. Get the entity types, IDs, and faces (for intersections) or the entity types, IDs, faces, depths and directions (for penetrations) for each intersected entity pair.
collision_type
The type of collision to query:
0 - intersections
1 - penetrations
component_index
The index of the component pair to query, starting from 0. The total number of component pairs for a specific collision_type can be found using hm_collisongetcomponentpaircount.
include_ignored (optional)
Specifies if results ignored when the allowable_depth value is specified via hm_collisioninit should be reported or not:
0 - Do not include ignored results (default).
1 - Include ignored results.
To find intersecting surfaces from IDs 1-10, and to get the detailed list of entities for each intersection:
*createmark surfs 1 1-10
hm_collisioninit
hm_collisionentitycreate surfs 1 0 1 0 0 0 0 0 0
hm_collisioncheck 0 0 1 0 0 0 0 90.0 0 0 0.0 1
set component_pair_count [hm_collisiongetcomponentpaircount 0]
if {$component_pair_count > 0} {
    for {set i 0} {$i < $component_pair_count} {incr i} {
        set component_pairs($i) [hm_collisiongetcomponentpair 0 $i]
        set entity_pair_count [hm_collisiongetcomponententitypaircount 0 $i]
        if {$pair_count != 0} {
            for {set j 0} {$j < $entity_pair_count} {incr j} {
                set entity_pairs($i,$j) [hm_collisiongetcomponententitypair 0 $i $j]
hm_collisionend
To find penetrating surfaces from IDs 1-10, using the thickness assigned to the surface components, and to get the detailed list of entities for each intersection:
hm_collisioninit
hm_collisioncheck 0 0 0 1 0 0 0 90.0 0 0 0.0 1
set component_pair_count [hm_collisiongetcomponentpaircount 1]
        set component_pairs($i) [hm_collisiongetcomponentpair 1 $i]
        set entity_pair_count [hm_collisiongetcomponententitypaircount 1 $i]
                set entity_pairs($i,$j) [hm_collisiongetcomponententitypair 1 $i $j]
hm_collisionend
   # Handle error
Version History
13.0
