hm_getentitytype
Returns the HyperMesh entity type ID for the passed entity type name.
hm_getentitytype entity_type
HyperMesh Tcl Query Command
This command returns the HyperMesh entity type ID for the specified entity_type. Each entity type in HyperMesh is assigned a unique ID. The entity type name is converted to the entity type ID using this command.
If entity_type is not valid, undefined will be returned.
This is the inverse of the hm_getentityname command.
entity_type
The unique entity type name.
Examples
To get the type ID of nodes (1):
hm_getentitytype nodes
To get the type ID of properties (11):
hm_getentitytype properties
None.
Version History
11.0
