hm_comparesetreview
Sets the graphical review type for comparison results.
hm_comparesetreview type ?min_legend? ?max_legend?
HyperMesh Tcl Query Command
Sets the graphical review type for comparison results. This must be preceded by a call to a relevant hm_compareentities* command. For distance review, a call must also be made to hm_comparefinddistances. This is cleared upon a call to hm_compareend.
- type
- 0 - Off
- min_legend (optional)
- Value that indicates the minimum value to use for the legend when type is 2. If not specified, the default is 0.0.
- max_legend (optional)
- Value that indicates the maximum value to use for the legend when type is 2. If not specified, the default is the maximum distance.
To generate a contour of the distance results for a same side comparison of elems 1-20 and 101-120:
*createmark elems 1 1-20
*createmark elems 2 101-120
hm_compareinit
hm_compareentitiessameside surfs 1 surfs 2 0.1 2 0
hm_comparefinddistances 1.0 1
hm_comparesetreview 2
hm_compareend
# Handle error
Version History
12.0
