hm_getclosestpointsbetweentwolines
Find the shortest distance between two lines and return line points corresponding to this distance.
hm_getclosestpointsbetweentwolines lineID1 lineID2
HyperMesh Tcl Query Command
- lineID1
- ID of the first line.
- lineID2
- ID of the second line.
The result is returned as a list: { x1 y1 z1 x2 y2 z2}
Where "x1", "y1", "z1" are coordinates of the closest point on the first line and "x2", "y2", "z2" are coordinates of the closest point on the second line.
To find closest points between lines with id 1 and 2:
hm_getclosestpointsbetweentwolines 1 2
2.682E+003 -7.365E+002 6.050E+002 2.685E+003 -7.350E+002 6.040E+002
None.
