hm_convertFromOutFileToDatFile
Generates a DAT file from an OUT file.
hm_convertFromOutFileToDatFile file_name
HyperMesh Tcl Query Command
The OUT file will be read and flutter summary data is collected, and the DAT file is generated in the same directory.
- file_name
- The name and path of the OUT file.
hm_convertFromOutFileToDatFile "C:/temp/flutter.out"Errors
# Handle error
}Version History
2019.1
