hm_getnodessharedbyothercomps
Returns the nodes on the input components that are shared by other components.
hm_getnodessharedbyothercomps comp_mark_id node_mark_id exclude
HyperMesh Tcl Query Command
This command returns the nodes on the input components that are shared by other components.
- comp_mark_id
- The ID of the input mark containing the components with the nodes of interest.
- node_mark_id
- The ID of the output mark containing the identified shared nodes.
- exclude
- 0 - Do not exclude any nodes.
*createmark comps 1 100
hm_getnodessharedbyothercomps 1 1 0Errors
# Handle error
}Version History
11.0.101
