hm_getsolidshelloverlapinfo
Returns information regarding proximity overlap between one/more solid cavity element(s) and structural components.
hm_getsolidshelloverlapinfo source_entity_type source_mark_id target_entity_type target_mark_id maxproximitydistance
HyperMesh Tcl Query Command
{<solid1_compid> <solid1_surfacearea> < solid1_volume> {{<overlapshell1_compid> <proximity_area_with solid1>} {<overlapshell2_compid> <proximity_area_with solid1>}}}Inputs
- source_entity_type
- The type of source entity. Currently supported for components. Only 3D elements are considered.
- source_mark_id
- The ID of the mark containing the source entities. Valid values are 1 and 2.
- target_entity_type
- The type of target entity. Currently supported for components. Only 2D elements are considered.
- target_mark_id
- The ID of the mark containing the target entities. Valid values are 1 and 2.
- maxproximitydistance
- Maximum proximity distance below which the overlap is calculated.
Examples
*createmark comps 1 20
*createmark comps 2 2 10 13
hm_getsolidshelloverlapinfo comps 1 comps 2 5.0Errors
# Handle error
}Version History
2021.2
