Query the values of global mesh parameters.
hm_getbatchparams
param1 ?param2? ?param3? ... ?paramN?
HyperMesh Tcl Query Command
- param
- The name of the parameter to query. Valid values can be found in
*batchparams_update.
- There are also a few special considerations:
- solid_holes_table = {row_id=<value}
- row_id is the index of the row (record) to query inside the
table. If not specified, the entire table is returned.
- surface_fillets_table = {row_id=<value}
- surface_holes_table = {table_id=<value> shape=<value>
row_id=<value>}
- table_id is the index of the table to query. If set to
‘default’, the default surface hole table is used. For coordinates tables, the
index starts with 0.
table_id. If not specified, the entire table with the
specified table_id is returned.
- shape is required for the default table.
Examples
To query the 2nd row of the first coordsfile
table:
hm_getbatchparams surface_holes_table = {table_id=0 row_id=1}
To query the entire default 2d rectangle holes
table:
hm_getbatchparams surface_holes_table = {table_id=default shape=rectangle}
To query the 1st row of 3d holes
table:
hhm_getbatchparams solid_holes_table = {row_id=0}
To query the entire 3d holes
table:
To query the 2nd row of fillet
table:
hm_getbatchparams surface_fillets_table = {row_id=1}
To query the entire fillet
table:
To get the element size:
hm_getbatchparams element_size
Incorrect usage results in a
Tcl error. To detect
errors, you can use the
catch
command:
# Handle error
Version History
2021
2021.1 - Updated the surface_holes_table options
and the list of examples.
