hm_ce_getdefaultconnectorcontrolfromconfig
Returns the connector control default name and ID for an FE config.
hm_ce_getdefaultconnectorcontrolfromconfig solver style feconfig
HyperMesh Tcl Query Command
- solver
- The solver name.
- style
- The connector style. Valid values are app_mass, area, bolt, seam and spot.
- feconfig
- The FE config name
Examples
Return the connector control default for solver nastran, style spot, and FE config "rbe3 (load transfer)":
set ctrl_info [hm_ce_getdefaultconnectorcontrolfromconfig nastran spot "rbe3 (load transfer)"]
# Handle error
Version History
2021
