hm_fe_getdvstfile
Returns the dvst file set for weld or property creation.
hm_fe_getdvstfile
HyperMesh Tcl Query Command
The diameter versus thickness is the global file set internally from the panel or through the commands.
set dtfile [ hm_fe_getdvstfile ];Errors
None.
