hm_compareentitiestranslate
Generates comparison results for entities translated along a vector.
hm_compareentitiestranslate source_entity_type source_mark_id target_entity_type target_mark_id tolerance vec_x vec_y vec_z distance steps ?result_type? ?review_results?
HyperMesh Tcl Query Command
Generates comparison results for entities translated along a vector. This may find multiple matches, depending on the requested options. This must be preceded by a call to hm_compareinit.
These results can then be queried using hm_compareget* APIs, or written to a file using hm_comparewrite* APIs.
source_entity_type
The type of source entity. Valid values are surfs or elems.
source_mark_id
The ID of the mark containing the source entities. Valid values are 1 and 2.
target_entity_type
The type of target entity. Valid values are surfs or elems.
target_mark_id
The ID of the mark containing the target entities. Valid values are 1 and 2.
tolerance
The tolerance value to use for the comparison.
vec_x
X-coordinate of translation direction.
vec_y
Y-coordinate of translation direction.
vec_z
Z-coordinate of translation direction.
distance
The translation distance to use for searching for matches.
steps
The number of steps to consider. This dictates how many increments of distance are searched for matches. For example, if distance is 45 and steps is 3, the distances 45, 90 and 135 will be searched. Must be ≥ 1.
result_type
  SURFS to SURFS SURFS to ELEMS ELEMS to SURFS ELEMS to ELEMS
0 - Basic
Matched (paired)
Unmatched
Matched (paired)
Unmatched
Matched
Unmatched
1 - Full (default)
Matched (paired)
Overlapped
Intersected
Unmatched
Matched (paired)
Overlapped
Intersected
Unmatched
Matched
Overlapped
Intersected
Unmatched
2 - Detailed
Matched (paired)
Overlapped (paired)
Intersected (paired)
Unmatched
Matched (paired)
Overlapped (paired)
Unmatched
Matched
Overlapped
Intersected
Unmatched
review_results
0 - Do not automatically show the graphical comparison results after execution.
1 - Automatically show the graphical comparison results after execution (default). This is cleared upon a call to hm_compareend.
To write the detailed comparison results file to C:/temp/my_compare.txt for the translational comparison using a distance of 45 and 6 steps, of surfs 1-20 and 101-120 along the y-direction:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiestranslate surfs 1 surfs 2 0.1 0 1 0 45 6 2 0
hm_comparewriteresults C:/temp/my_compare.txt
hm_compareend
   # Handle error
Version History
12.0
