hm_getshelloverlapinfo
Returns information regarding proximity overlap between a selection of components or elements.
hm_getshelloverlapinfo source_entity_type source_mark_id target_entity_type target_mark_id maximumproximitydistance
HyperMesh Tcl Query Command
<proximity_area> <proximity_volume> <max_proximity_distance> <min_proximity_distance> (Bounding Box info){{MinPointX MinPointY MinPointZ} {MaxPointX MaxPointY MaxPointZ}} (PCA Box info){{OriginX OriginY OriginZ} {XVectorX XVectorY XVectorZ} {YVectorX YVectorY YVectorZ} {ZVectorX ZVectorY ZVectorZ}}Inputs
- source_entity_type
- The type of source entity. Currently supported for components and elements.
- source_mark_id
- The ID of the mark containing the source entities. Valid values are 1 and 2.
- target_entity_type
- The type of target entity. Currently supported for components and elements.
- target_mark_id
- The ID of the mark containing the target entities. Valid values are 1 and 2.
- maxproximitydistance
- Maximum proximity distance below which the overlap is calculated.
Examples
*createmark comps 1 7100314
*createmark comps 2 7100361
hm_getshelloverlapinfo comps 1 comps 2 5.0Errors
# Handle error
}Version History
2021.2
