hm_tabletomark
Append the entity IDs from the named table to the specified mark.
hm_tabletomark table_name mark_id
HyperMesh Tcl Query Command
This command appends the entity IDs stored in table_name to mark mark_id. Valid mark_ids are 1 and 2.
Tables are not stored within a HyperMesh database (.hm file). When the current model is deleted or a new model is loaded, all tables are cleared.
If a table contains an entity that is subsequently deleted, the entity is removed from the table. Renumbering does not modify the entity IDs stored in the table.
elem_table on element mark
1:hm_tabletomark elem_table 1Errors
# Handle error
}hm_marktotable: the table <table_name> was not found.hm_marktotable: invalid mark mask <mark_id> specified, must be either 1 or 2.hm_marktotable: no entities were found on the mark.Version History
2023 - Deprecated argument panel_sensitive.
