hm_collisionvisualizebymark
Enables the visualization of collision entities using one of various supported visualization modes.
hm_collisionvisualizebymark mark_id node_mark_id review_type fit_view display_type
HyperMesh Tcl Query Command
- mark_id
- The ID of the mark containing the collision entities to be visualized. Valid values are 1 and 2.
- node_mark_id
- The ID of the mark containing the secondary nodes from the collision entities on mark_id. Only these nodes will be visualized. Valid values are 1 and 2.
- review_type
- A flag that indicates the type of visualization. Valid values are:
- fit_view
- 0 - Do not fit view
- display_type
- A flag that indicates which elements to display. Valid values are:
Examples
set config [hm_collisiongetconfig collirad intersections];
*clearmark comps 1 all;
eval *createmark comps 1 1001 1002;
*collisioncheck2_temp comps 1 $config 0.0 0.0 0.0 0.0;
*createmark collisions 1 all;
hm_collisionvisualizebymark 1 0 1 1 2;set config [hm_collisiongetconfig collirad penetrations];
hm_collisionvisualizebymark 1 0 3 0 3;Errors
# Handle error
}Version History
2019
