hm_getcardimageoptions
Returns information about certain options supported by a card image.
hm_getcardimageoptions entity_type card_image option
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query. Currently supported for props.
- card_image
- The name of the card image to query e.g. P1_SHELL. Only card images for the current template are supported.
- option
- The option value to query for the entity type. Valid values for props are:
- material
- Returns 1 if the entity allows a direct material assignment, 0 otherwise.
- beamsection
- Returns 1 if the entity allows a direct beamsect assignment, 0 otherwise.
- beamsection_attrib
- If beamsection option returns 1 this returns the attribute to use to assign the beamsection, 0 otherwise.
- thickness
- Returns 1 if the panel allows a direct material assignment, 0 otherwise.
- thickness_attrib
- If thickness option returns 1 this returns the attribute to use to assign the thickness value, 0 otherwise.
Examples
hm_getcardimageoptions props P1_SHELL material
0
hm_getcardimageoptions props P1_SHELL beamsection
0
hm_getcardimageoptions props P1_SHELL beamsection_attrib
0
hm_getcardimageoptions props P1_SHELL thickness
1
hm_getcardimageoptions props P1_SHELL thickness_attrib
431hm_getcardimageoptions props PBEAM material
1
hm_getcardimageoptions props PBEAM beamsection
1
hm_getcardimageoptions props PBEAM beamsection_attrib
3186
hm_getcardimageoptions props PSHELL thickness
0
hm_getcardimageoptions props PSHELL thickness_attrib
0Errors
# Handle error
