hm_findnarrowsurfaces
Returns the list of narrow surfaces, including large surfaces with narrow tails or local narrow neck regions.
hm_findnarrowsurfaces entity_type mark_id width_threshold ?output_surfs_flag? ?sharp_angle_threshold? ?reserved?
HyperMesh Tcl Query Command
The output is a list of the narrow surface IDs.
- 1 - Sliver surface
- 2 - Surface containing a narrow neck region
- 4 - Surface containing a narrow tail region
The value for each surface can be either 1, 2, 4 or 6 (the surface contains both a neck and a tail).
- entity_type
- The type of entity to query. Valid values are surfs, solids and comps.
- mark_id
- The ID of the mark containing the entities. Valid values are 0, 1 and 2. If set to 0, all corresponding entities are considered.
- width_threshold
- Positive value defining the maximal width of a narrow surface, or maximal gap for a surface narrow tail or neck region.
- output_surfs_flag (optional)
- Parameter defining the type of output.
- sharp_angle_threshold (optional)
- An angle, in degrees, that represents a corner angle above which the area nearby a surface corner is not considered as a narrow region. Default value is 10 degrees.
- reserved
- Reserved for future use. Must be set to 0.
Examples
To find narrow surfaces with width below 0.2 mm for component "main_body" :
*createmark comps 1 main_body
hm_findnarrowsurfaces comps 1 0.2
718 621 594 589 569 516 232 230 222 220 212 177 36 29
hm_findnarrowsurfaces comps 1 0.2 1
{718 621 594 589 569 516 232 230 222 220 212 177 36 29} {4 1 4 4 4 2 4 4 1 4 4 6 4 2}Errors
# Handle error
}Version History
14.0.130
2023 - Deprecated argument panel_sensitive.
