hm_saveusermark
Store the entity IDs of the passed entity type on the user mark.
hm_saveusermark entity_type mark_id
HyperMesh Tcl Query Command
This command stores the IDs of entity_type that exist on mark_id on the user mark. Valid mark_ids are 1 and 2. Only one user mark exists for each entity_type.
The user mark is accessed either through the command hm_getusermark or through panel input collectors, hm_createmark and hm_appendmark via the "retrieve" option.
To save the user mark of properties 1,3 and 5:
m_createmark props 1 "by id only" "1 3 5"
hm_saveusermark props 1
To create a mark of elements 1-3, save it to the element user mark and retrieve it later:
hm_createmark elems 1 "1 2 3"
hm_saveusermark elems
hm_markclear elems 1
hm_getusermark elems
# Handle error
}If mark_id is invalid, you will get the following error:
hm_saveusermark: invalid markmask specified
Version History
2023 - Deprecated argument panel_sensitive.
