hm_runcommandfile
Runs a HyperMesh command file specified by a complete path and filename.
hm_runcommandfile filename ?prompt?
HyperMesh Tcl Query Command
This command can be used to execute a HyperMesh command file (*.cmf) from within a Tcl script. In the case there is an error in one of the lines of the command file, the command execution continues without prompting if the user wants to continue.
- filename
- The full path and filename of the command file. Note that forward slashes (/) are required in the path and filename, the name must be wrapped in curly braces {}, or the backwards slash (\) must be escaped. Paths with spaces must be enclosed in quotes or curly braces. These are Tcl requirements.
- prompt (optional)
- Argument specifying whether to ignore the *answer command in the command file (default, 0) or to honor the *answer command when present (1).
Examples
hm_runcommandfile C:/solidedit/command1.cmfhm_runcommandfile {C:\solidedit\command1.cmf}hm_runcommandfile C:\\solidedit\\command1.hm_runcommandfile "C:/solid edit/command1.cmf"hm_runcommandfile {C:/solid edit/command1.cmf}Errors
None.
Version History
9.0
