Returns details about a specific hole/tube.
hm_holedetectiongetholedetails
index
HyperMesh Tcl Query Command
Returns details about a specific hole/tube. This must be preceded by a call to
hm_holedetectionfindholes.
- index
- The index of the hole to get details for, starting from 0 up to the number of found
holes minus 1.
- General
hole:
0 0 {center x/y/z} {axis x/y/z} {entities ordered lines/nodes} {0 - No washer elements, 1 - Washer elements; Always 0 for geometry holes}
- Circular
hole:
0 1 radius {center x/y/z} {axis x/y/z} {entities ordered lines/nodes} {0 - No washer elements, 1 - Washer elements; Always 0 for geometry holes}
- Rounded
hole:
0 2 radius1 {center1 x/y/z} radius2 {center2 x/y/z} length {center x/y/z} {axis x/y/z} {entities ordered lines/nodes} {0 - No washer elements, 1 - Washer elements; Always 0 for geometry holes}
- Square
hole:
0 3 length {center x/y/z} {axis x/y/z} {entities ordered lines/nodes} {0 - No washer elements, 1 - Washer elements; Always 0 for geometry holes}
- Rectangular
hole:
0 4 length width {center x/y/z} {axis x/y/z} {entities ordered lines/nodes} {0 - No washer elements, 1 - Washer elements; Always 0 for geometry holes}
- General
tube:
1 0 {center_top x/y/z} {axis_top x/y/z} {rim_entities_top ordered lines/nodes} depth {tube_entities surfaces/shells/solids and face indicies} capped_flag {center_bottom x/y/z} {axis_bottom x/y/z} {rim_entities_bottom ordered lines/nodes}
- Circular
tube:
1 1 radius_top {center_top x/y/z} {axis_top x/y/z} {rim_entities_top ordered lines/nodes} depth {tube_entities surfaces/shells/solids and face indicies} capped_flag radius_bottom {center_bottom x/y/z} {axis_bottom x/y/z} {rim_entities_bottom ordered lines/nodes}
- Rounded
tube:
1 2 radius1_top {center1_top x/y/z} radius2_top {center2_top x/y/z} length_top {center_top x/y/z} {axis_top x/y/z} {rim_entities_top ordered lines/nodes} depth {tube_entities surfaces/shells/solids and face indicies} capped_flag radius1_bottom {center1_bottom x/y/z} radius2_bottom {center2_bottom x/y/z} length_bottom {center_bottom x/y/z} {axis_bottom x/y/z} {rim_entities_bottom ordered lines/nodes}
- Square
tube:
1 3 length_top {center_top x/y/z} {axis_top x/y/z} {rim_entities_top ordered lines/nodes} depth {tube_entities surfaces/shells/solids and face indicies} capped_flag length_bottom {center_bottom x/y/z} {axis_bottom x/y/z} {rim_entities_bottom ordered lines/nodes}
- Rectangular
tube:
1 4 length_top width_top {center_top x/y/z} {axis_top x/y/z} {rim_entities_top ordered lines/nodes} depth {tube_entities surfaces/shells/solids and face indicies} capped_flag length_bottom width_bottom {center_bottom x/y/z} {axis_bottom x/y/z} {rim_entities_bottom ordered lines/nodes}
To write out all geometric shell hole details to a file named
C:/temp/holes.txt:
set holesfile [open "C:/temp/holes.txt" "w"]
hm_holedetectioninit
*createmark surfs 1 all
hm_holedetectionsetentities surfs 1
hm_holedetectionsetholeparams hole_shape=31
hm_holedetectionfindholes 1
set n [hm_holedetectiongetnumberofholes]
if { $n > 0 } {
puts $holesfile "Number of holes = $n"
puts $holesfile "Holes details"
for {set i 0} {$i < $n} {incr i} {
puts $holesfile "i = $i [hm_holedetectiongetholedetails $i]"
} else {
puts $holesfile "Holes not detected."
hm_holedetectionend
close $holesfile
Incorrect usage results in a
Tcl error. To detect
errors, you can use the
catch
command:
# Handle error
Version History
14.0
2020.1 - Resolved an issue where FE holes would always return the hole
type as general.
