hm_getmodelcheckcheckresult
Returns the result for a given check.
hm_getmodelcheckcheckresult check_display_name
HyperMesh Tcl Query Command
- <flag> - True if check is run and false otherwise
- <number of failed entities> - The count of failed entities
- <entity IDs> - The IDs of the failed entities
For example: true 4 46 47 48 49
- check_display_name
- The GUI display name of the check. This is case sensitive.
Examples
To get the result for the "Unused materials" check:
hm_getmodelcheckcheckresult "Unused Materials"
# Handle error
Version History
2019
