Returns the thickness of the specified component, element or property.
hm_getthickness
entity_type entity_id ?ply_id?
HyperMesh Tcl Query Command
This command returns the thickness value for an entity.
- entity_type
- The type of entity to query. Valid values are comps, elems and props.
- For an entity_type of components the following applies:
- If the component has a property directly assigned, the thickness of the property is
returned.
- If no property is assigned to the component, nothing is returned.
- For an entity_type of elements the following applies:
- If the element has a property assigned, the thickness of the property is returned.
- If no property is assigned directly to the element, use the component rules as
above.
- entity_id
- The ID of the entity to query.
- ply_id
- Optional argument that allows for additional control for querying the thickness of
individual plies of composites.
- Used as follows for metallic properties: If not specified, returns the thickness.
- If specified as 1, returns the thickness as (a).
- Any other value will return an error.
- Used as follows for composite properties:
- If not specified, returns the total thickness (sum of all ply thicknesses).
- If a valid ply is specified, returns the thickness of that ply.
Examples
Get the thickness value of component 11 which has a PSHELL property with thickness of
0.25:
hm_getthickness comps 11
0.25
hm_getthickness comps 11 1
0.25
hm_getthickness comps 11 2
2 is not a valid ply ID.
Get the thickness value of component 15 which has a PCOMP property with 4 plys (thickness
values of 0.1, 0.25, 0.25, 0.1, total of 0.7):
hm_getthickness comps 15
0.7
hm_getthickness comps 15 1
0.1
hm_getthickness comps 15 2
0.25
hm_getthickness comps 15 3
0.25
hm_getthickness comps 15 4
0.1
hm_getthickness comps 15 5
5 is not a valid ply ID.
Get the thickness value of element 20 which has a PSHELL property with thickness of
0.25:
hm_getthickness elems 20
0.25
Get the thickness value of element 20 which does not have a property assigned but belongs
to a component that has a PSHELL property with thickness of
0.25:
0.25
Get the thickness value of element 20 which does not have a property assigned and belongs
to a component that does not have a property
assigned:
Incorrect usage results in a
Tcl error. To detect
errors, you can use the
catch
command:
# Handle error
