Notes and Limitations
Notes and Limitations for hm_getvalue.
There are several issues, limitations and special behaviors of hm_getvalue that are important to know.
The command does not consider the status of the attribute. It is recommended users check the status separately.
The row=<row_index> option is not currently applicable or supported for the following entity types and data names.
- connectors
- elements
- lines
- nodes
- points
- solids
- surfaces
- interfacepairplyids
- vonmises
- marked_columnlabel
Certain entity data names have special behaviors.
- entitylist
- Row specifies the entity type and column specifies the index in the array.
- independentcoeffs
- independentdofs
- Row is the node ID of the DOF/COEFF.
- exceptids
- ids
- internalids
- For a normal set, row specifies the index of the array.
- For a formula set, row specifies the clauseindex and column specifies the index in the array.
