accelerometers
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- config
- The configuration of the entity.
- curve_id
- If igrav_gt is true, the ID of the curve defining the gravitation flag versus time.
- cutoff
- The cutoff frequency.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- igrav
- If igrav_gt is false, the gravitational accelerations due to body force loads.
- igrav_gt
- If true, IGRAV converts to a curve and curve_id is used.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- intopt
- The integration option.
- mass
- The added mass.
- multi_nodes
- The IDs of the base, x-axis and x-y plane nodes. Valid for hm_getvalue query only.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- node1
- The ID of the base node.
- node2
- The ID of the x-axis node.
- node3
- The ID of the x-y plane node.
- nodeid
- The ID of the accelerometer base node.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- skewid
- The ID of the skew node.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2019 - Added new data names cutoff, nodeid and skewid. Added config 201.
2020 - Added new data names color_rgb, curve_id and igrav_gt.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
