objectives
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- configname
- The solver name of the entity. Valid for hm_getvalue query only.
- definedentity
- True if the entity is defined, false otherwise.
- dobjreflist
- The list of dobjrefs that refer to the objective. Valid for hm_getvalue query only.
- dobjreflistmax
- The number of dobjrefs that refer to the objective. Valid for hm_getvalue query only.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- loadstepid
- The ID of the assigned loadstep.
- minmaxflag
- Objective type flag. Valid values are:
- 0 - minimize
- 1 - maximize
- 2 - minmax
- 3 - maxmin
- minmaxflagname
- Objective type flag name. Valid for hm_getvalue query only.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- responseid
- The ID of the assigned response.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
