dampings
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- ACOUSTIC_CURVE
- The ID of the curve for inplane bending value.
- ACOUSTIC_CURVE_OPTION
- The flag activating the use of the curve for the inplane bending value.
- ACOUSTIC_SCALE_FACTOR
- The curve scale factor for the inplane value if given as the curve input.
- acoustic_type
- The type of acoustic damping in SEAM.
- Acoustic_VALUE
- The value of the acoustic damping.
- Alpha
- The mass damping coefficient for all DOF or translational DOF in the x-direction.
- Alpha_y
- The mass damping coefficient for translational DOF in the y-direction.
- Alpha_z
- The mass damping coefficient for translational DOF in the z-direction.
- Alpha_xx
- The mass damping coefficient for rotational DOF in the xx-direction.
- Alpha_yy
- The mass damping coefficient for rotational DOF in the yy-direction.
- Alpha_zz
- The mass damping coefficient for rotational DOF in the zz-direction.
- attributesmax
- The number of attributes owned by this entity.
- Bending
- The bending value.
- BENDING_CURVE
- The ID of the curve for the bending value.
- BENDING_CURVE_OPTION
- The flag activating the use of a curve for the bending value.
- Bending_Option
- The flag activating the use of the bending option.
- BENDING_SCALE_FACTOR
- The curve scale factor for the bending value if given as curve input.
- Beta
- The stiffness damping coefficient for all DOF or translational DOF in the x-direction.
- Beta_y
- The stiffness damping coefficient for translational DOF in the y-direction.
- Beta_z
- The stiffness damping coefficient for translational DOF in the z-direction.
- Beta_xx
- The stiffness damping coefficient for rotational DOF in the xx-direction.
- Beta_yy
- The stiffness damping coefficient for rotational DOF in the yy-direction.
- Beta_zz
- The stiffness damping coefficient for rotational DOF in the zz-direction.
- CDAMP
- The fraction of critical damping.
- COEF
- The Rayleigh damping coefficient.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- DAMPINGS_TYPE
- The type of structural damping in SEAM.
- definedentity
- True if the entity is defined, false otherwise.
- DEFORM
- True to apply damping to element deformation.
- DV2
- The optional constant for velocity squared term.
- FHIGH
- The highest frequency in the range of interest.
- FLAG
- Set to 1 to enable separate scale factors for global component of damping forces.
- FLOW
- The lowest frequency in the range of interest.
- Fraction_Coverage
- The value of the fraction coverage.
- Freelayer_treatment_Option
- The flag activating the use of the freelayer treatment option.
- FREQ
- The frequency at which CDAMP applies.
- grnod_id
- The node group identifier.
- IFLAG
- The method used for internal calculation of damping.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- Inplane
- The value of inplane bending.
- INPLANE_CURVE
- The ID of the curve for the inplane bending value.
- INPLANE_CURVE_OPTION
- The flag activating the use of a curve for the inplane bending value.
- Inplane_Option
- The flag activating the use of the inplane bending option.
- INPLANE_SCALE_FACTOR
- The curve scale factor for the inplane value if given as curve input.
- internalid
- internalname
- The internal name of the entity.
- Layer_offset
- The value of the layer offset.
- Layer_Thickness
- The thickness value of the freelayer.
- LCID
- The load curve ID to specify the damping constant versus time.
- Mass_Damp_Factor_Option
- True to enable optional mass damp factors.
- material
- The ID of the layer material.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- Nb_time_step
- The number of time steps.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- PID
- The part ID.
- PIDRB
- The part ID of rigid body.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- PSID
- The part set ID.
- SF
- The scale factor for LCID.
- SID_TYPE
- 0 - Part ID (*PART)
- skew_id
- The skew identifier.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- SRX
- The scale factor for global x rotational damping forces.
- SRY
- The scale factor for global y rotational damping forces.
- SRZ
- The scale factor for global z rotational damping forces.
- STX
- The scale factor for global x translational damping forces.
- STY
- The scale factor for global y translational damping forces.
- STZ
- The scale factor for global z translational damping forces.
- Tstart
- The start time.
- Tstop
- The end time.
- VALDAMP
- The system damping constant.
Version History
2019.1
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names ACOUSTIC_CURVE, ACOUSTIC_CURVE_OPTION, ACOUSTIC_SCALE_FACTOR, acoustic_type, Acoustic_VALUE, Bending, BENDING_CURVE, BENDING_CURVE_OPTION, Bending_Option, BENDING_SCALE_FACTOR, DAMPINGS_TYPE, Fraction_Coverage, Freelayer_treatment_Option, Inplane, INPLANE_CURVE, INPLANE_CURVE_OPTION, Inplane_Option, INPLANE_SCALE_FACTOR, internalname, Layer_offset, Layer_Thickness, material, and solvername.
