properties
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- cardimage
- The name of the assigned card image.
- cardimagetype
- The type of the assigned card image.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- encrypted
- True if the entity is encrypted, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- laminate
- The ID of the laminate linked to the property (for example, /PROP/STACK or /PROP/TYPE51). This data name is not used for other properties in Radioss, nor at all in other profiles.
- material
- A pointer to the material assigned to the property. This will always be a valid material ID if one is assigned.
- materialid
- The ID of the material assigned to the property. This could be a valid material ID or unresolved material ID.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poleforpmlCoordinates
- The XP, YP, and ZP coordinates of a pole for PML.
- poleforpmlnodeid
- The ID of the pole node for PML.
- poleforpmltype
- The type of pole for PML.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- section
- The ID of the section entity assigned to the property.
- sensor
- The ID of the sensor entity assigned to the property.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- thickness
- The thickness of the property. This is only available for "core" solver templates routinely maintained by Altair.
Version History
2017.2 - Added new data name laminate.
2019 - Added new data name thickness.
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022 - Added new data names section and sensor.
2022.1 - Added new data names poleforpmlCoordinates, poleforpmlnodeid, and poleforpmltype.
