seamjunctions
Unless otherwise specified, data names are accessible in level 3 only.
- A_DimType
- The dimension type of Acoustic connection.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- ACOUSTIC_BOTTOM
- The bottom acoustic seasubsystem associated with structural-acoustic connection.
- ACOUSTIC_ELEM1
- The top acoustic seasubsystem associated with acoustic connection.
- ACOUSTIC_ELEM2
- The bottom acoustic seasubsystem associated with acoustic connection.
- ACOUSTIC_TOP
- The top acoustic seasubsystem associated with structural-acoustic connection.
- Area
- The area of structural acoustic connection.
- Area_Val
- The area of acoustic connection.
- attributesmax
- The number of attributes owned by this entity.
- BARRIER
- The barrier seasubsystem associated with structural-acoustic connection.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- DimType
- The dimension type of the structural connection.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- JUNC_LINES
- The graphics (lines) attached to seamjunctions.
- JUNC_POINTS
- The graphics (points) attached to seamjunctions.
- JUNC_SURFACES
- The graphics (surfaces) attached to seamjunctions.
- Length
- The length of the structural connection for line and arc dimension types.
- LRad
- The radiation length of the structural acoustic connection.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- Number
- The number of points in the point dimension type of the structural connection.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- S_TemplateType
- The template type of structural connection.
- SA_TemplateType
- The template type of structural acoustic connection.
- SEAMJUNCTION_CON_ID
- The ID of the element.
- SEAMJUNCTION_ID
- The ID of the SEAM junction solver entity.
- SEAMJUNCTION_TYPE
- The type of SEAM junction solver entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- STRUCTURE
- The structural seasubsystem associated with structural-acoustic connection.
- STRUCTURE_A
- STRUCTURE_B
- STRUCTURE_C
- STRUCTURE_D
- STRUCTURE_E
- STRUCTURE_F
- STRUCTURE_G
- STRUCTURE_H
- STRUCTURE_I
- TRIMLAYER
- The trimlayer seasubsystem associated with structural-acoustic connection.
- Width
- The width of the structural acoustic connection.
Version History
2021.2
2022 –Added new data names acoustic_bottom, acoustic_elem1, acoustic_elem2, acoustic_top, barrier, junc_lines, junc_points, junc_surfaces, structure, structure_a, structure_b, structure_c, structure_d, structure_e, structure_f, structure_g, structure_h, structure_i, and trimlayer.
