noisecontroltreatments
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- FIELD_ANGLE
- Value of field angle of NCTs.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- layer1
- The first nctlayer ID.
- layer2
- layer3
- layer4
- layer5
- layer6
- layer7
- layer8
- layer9
- layer10
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- numoflayers
- The number of NCT layers ranging from 1-10.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2022
