memberpanels
Unless otherwise specified, data names are accessible in level 3 only.
- _baseFlags
 - The base flag of the entity.
 - _representations
 - The representations of the entity.
 - _representations_functionalrepresentation
 - The functional representations of the entity.
 - _representations_geometricrepresentation
 - The geometric representations of the entity.
 - _representations_solverrepresentation
 - The solver representations of the entity.
 - _subType
 - The sub type of the entity.
 - activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - members
 - The members entities defining the panel boundary.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - primaryrepresentation
 - The current representation of the panel.
 - shrinkoffset
 - The shrinking ratio to realize the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - symmetryid
 - The plane entity if panel was created from a symmetry.
 - symmetryparent
 - The ID of the parent member panel used for symmetry.
Version History
2022
