ellipsoids
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- center
- The global coordinates of the center of gravity. Valid hm_getvalue query only.
- centerx
- The global x-coordinate of the center of gravity.
- centery
- The global y-coordinate of the center of gravity.
- centerz
- The global z-coordinate of the center of gravity.
- collector
- Pointer to the multibody that owns the ellipsoid.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- localcenterx
- The local x-coordinate of the center of gravity.
- localcentery
- The local y-coordinate of the center of gravity.
- localcenterz
- The local z-coordinate of the center of gravity.
- moduleid
- The module ID of the entity.
- multibodyid
- The ID of the owning multibody.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- radius
- The principle radii. Valid for hm_getvalue query only.
- radiusa
- The first principle radius of the ellipsoid.
- radiusb
- The second principle radius of the ellipsoid.
- radiusc
- The third principle radius of the ellipsoid.
- shape
- shape The shape factor (N) for the ellipsoid.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- systemid
- The ID of the system used to orient the ellipsoid.
- type
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
