multibodies
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - cardimage
 - The name of the assigned card image.
 - cardimagetype
 - The type of the assigned card image.
 - center
 - The global coordinates of the center of gravity. Valid for hm_getvalue query only.
 - centerx
 - The x coordinate of the element centroid.
 - centery
 - The y coordinate of the element centroid.
 - centerz
 - The z coordinate of the element centroid.
 - definedentity
 - True if the entity is defined, false otherwise.
 - globalx
 - The global x coordinate of the center of gravity.
 - globaly
 - The global y coordinate of the center of gravity.
 - globalz
 - The global z coordinate of the center of gravity.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - localcenter
 - The local coordinates of the center of gravity. Valid for hm_getvalue query only.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - system
 - A pointer to the local coordinate system of the multibody.
 - systemid
 - The ID of the local coordinate system of the multibody.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
