desvarlinks
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- c0
- The value of the constant used in DLINK.
- cmult
- The value of the constant multiplier used in DLINK.
- coeff
- A pointer to the coefficients of independent design variables contained in the desvarlink.
- configname
- The solver keyword for the entity. Valid values are 1 and 2.
- definedentity
- True if the entity is defined, false otherwise.
- desvarid
- The ID of the dependent design variable.
- desvarlist
- A pointer to the list of independent design variable IDs contained in the desvarlink.
- desvarlistmax
- The number of independent design variables in the desvarlink.
- functionid
- The ID of the optimization equation.
- functype
- The type of the pre-defined function used to create the desvarlink. Valid values are:
- functypename
- The name of the pre-defined function used to create the desvarlink. Valid for hm_getvalue query only.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- markertype
- The marker type used to indicate points on the curve.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- tableentrylist
- A pointer to the list of table entry IDs contained in the desvarlink.
- tableentrylistmax
- The number of table entries in the desvarlink.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
