opticontrols
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- almtostr
- The ALMTOSTR (Augmented Lagrange Method) value.
- almtostrtoggle
- The ALMTOSTR (Augmented Lagrange Method) toggle on (1) or off (0) state.
- approx
- APPROX value.
- approxtoggle
- APPROX toggle on (1) or off (0) state.
- attributesmax
- The number of attributes owned by this entity.
- barcon
- BARCON value.
- barcontoggle
- BARCON toggle on (1) or off (0) state.
- checker
- CHECKER value.
- checkertoggle
- CHECKER toggle on (1) or off (0) state.
- config
- The configuration of the entity.
- configname
- The solver name of the entity. Valid for hm_getvalue query only.
- ddvopt
- DDVOPT value.
- ddvopttoggle
- DDVOPT toggle on (1) or off (0) state.
- definedentity
- True if the entity is defined, false otherwise.
- contol
- CONTOL value.
- contoltoggle
- CONTOL toggle on (1) or off (0) state.
- delshp
- DELSHP value.
- delshptoggle
- DELSHP toggle on (1) or off (0) state.
- delsiz
- DELSIZ value.
- delsiztoggle
- DELSIZ toggle on (1) or off (0) state.
- deltop
- DELTOP value.
- deltoptoggle
- DELTOP toggle on (1) or off (0) state.
- desmax
- DESMAX value.
- desmaxtoggle
- DESMAX toggle on (1) or off (0) state.
- discrete
- DISCRETE value.
- discretetoggle
- DISCRETE toggle on (1) or off (0) state.
- discrt1d
- DISCRT1D value.
- discrt1dtoggle
- DISCRT1D toggle on (1) or off (0) state.
- eslmax
- ESLMAX value.
- eslmaxtoggle
- ESLMAX toggle on (1) or off (0) state.
- eslsopt
- ESLSOPT value.
- eslsopttoggle
- ESLSOPT toggle on (1) or off (0) state.
- eslstol
- ESLSTOL value.
- eslstoltoggle
- ESLSTOL toggle on (1) or off (0) state.
- gbuck
- GBUCK value.
- gbucktoggle
- GBUCK toggle on (1) or off (0) state.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- matinit
- MATINIT value.
- matinittoggle
- MATINIT toggle on (1) or off (0) state.
- maxbuck
- MAX_BUCK value.
- maxbucktoggle
- MAX_BUCK toggle on (1) or off (0) state.
- mindens
- MINDENS value.
- mindenstoggle
- MINDENS toggle on (1) or off (0) state.
- mindim
- MINDIM value.
- mindimtoggle
- MINDIM toggle on (1) or off (0) state.
- minmeth
- MINDIM value.
- minmethtoggle
- MINMETH toggle on (1) or off (0) state.
- mmcheck
- MMCHECK value.
- mmchecktoggle
- MMCHECK toggle on (1) or off (0) state.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- nastran_int_controls
- Pointer to the integer values.
- nastran_real_controls
- Pointer to the real values.
- nastran_toggles
- Pointer to the opticontrol toggle list of on (1) or off (0) values for Nastran.
- neslexpd
- NESLEXPD value.
- neslexpdtoggle
- NESLEXPD toggle on (1) or off (0) state.
- neslimpd
- NESLIMPD value.
- neslimpdtoggle
- NESLIMPD toggle on (1) or off (0) state.
- neslnlgm
- NESLNLGM value.
- neslnlgmtoggle
- NESLNLGM toggle on (1) or off (0) state.
- objtol
- OBJTOL value.
- objtoltoggle
- OBJTOL toggle on (1) or off (0) state.
- optmeth
- OPTMETH value.
- optmethtoggle
- OPTMETH toggle on (1) or off (0) state.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- remesh
- REMESH value.
- remeshtoggle
- REMESH toggle on (1) or off (0) state.
- restart
- RESTART value.
- restarttoggle
- RESTART toggle on (1) or off (0) state.
- shapeopt
- SHAPEOPT value.
- shapeopttoggle
- SHAPEOPT toggle on (1) or off (0) state.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- tminply
- TMINPLY value.
- tminplytoggle
- TMINPLY toggle on (1) or off (0) state.
- topdisc
- TOPDISC value.
- topdisctoggle
- TOPDISC toggle on (1) or off (0) state.
- topdv
- TOPDV value.
- topdvtoggle
- TOPDV toggle on (1) or off (0) state.
LATPRM config
- bucksf
- Buckling safety factor BUCKSF value.
- bucksftoggle
- Buckling safety factor BUCKSF toggle on (1) or off (0) state.
- clean
- CLEAN value.
- cleantoggle
- CLEAN toggle on (1) or off (0) state.
- latlb
- LATLB value.
- latlbtoggle
- LATLB toggle on (1) or off (0) state.
- maxrad
- MAXRAD value.
- maxradtoggle
- MAXRAD toggle on (1) or off (0) state.
- minrad
- MINRAD value.
- minradtoggle
- MINRAD toggle on (1) or off (0) state.
- ossrmsh
- OSSRMSH value.
- ossrmshtoggle
- OSSRMSH toggle on (1) or off (0) state.
- porosity
- POROSITY value.
- porositytoggle
- POROSITY toggle on (1) or off (0) state.
- r2lratio
- R2LRATIO value.
- r2lratiotoggle
- R2LRATIO toggle on (1) or off (0) state.
- strmeth
- STRMETH value.
- strmethtoggle
- STRMETH toggle on (1) or off (0) state.
- tetsplt
- TETSPLT value.
- tetsplttoggle
- TETSPLT toggle on (1) or off (0) state.
DOPTPRM config.
- aprcod
- APRCOD value.
- aprcodtoggle
- APRCOD toggle on (1) or off (0) state.
- conv1
- CONV1 value.
- conv1toggle
- CONV1 toggle on (1) or off (0) state.
- conv2
- CONV2 value.
- conv2toggle
- CONV2 toggle on (1) or off (0) state.
- convdv
- CONVDV value.
- convdvtoggle
- CONVDV toggle on (1) or off (0) state.
- convpr
- CONVPR value.
- convprtoggle
- CONVPR toggle on (1) or off (0) state.
- ct
- CT value.
- cttoggle
- CT toggle on (1) or off (0) state
- ctmin
- CTMIN value.
- ctmintoggle
- CTMIN toggle on (1) or off (0) state.
- dabobj
- DABOBJ value.
- dabobjtoggle
- DABOBJ toggle on (1) or off (0) state.
- delb
- DELB value.
- delbtoggle
- DELB toggle on (1) or off (0) state.
- delobj
- DELOBJ value.
- delobjtoggle
- DELOBJ toggle on (1) or off (0) state.
- delp
- DELP value.
- delptoggle
- DELP toggle on (1) or off (0) state.
- delx
- DELX value.
- delxtoggle
- DELX toggle on (1) or off (0) state.
- dobj1
- DOBJ1 value.
- dobj1toggle
- DOBJ1 toggle on (1) or off (0) state.
- dobj2
- DOBJ2 value.
- dobj2toggle
- DOBJ2 toggle on (1) or off (0) state.
- dpmin
- DPMIN value.
- dpmintoggle
- DPMIN toggle on (1) or off (0) state.
- dx1
- DX1 value.
- dx1toggle
- DX1 toggle on (1) or off (0) state.
- dx2
- DX2 value.
- dx2toggle
- DX2 toggle on (1) or off (0) state.
- dxmin
- DXMIN value.
- dxmintoggle
- DXMIN toggle on (1) or off (0) state.
- gmax
- GMAX value.
- gmaxtoggle
- GMAX toggle on (1) or off (0) state.
- gscal
- GSCAL value.
- gscaltoggle
- GSCAL toggle on (1) or off (0) state.
- igmax
- IGMAX value.
- igmaxtoggle
- IGMAX toggle on (1) or off (0) state.
- iprint
- IPRINT value.
- iprinttoggle
- IPRINT toggle on (1) or off (0) state.
- iprint1
- IPRINT1 value.
- iprint1toggle
- IPRINT1 toggle on (1) or off (0) state.
- iprint2
- IPRINT2 value.
- iprint2toggle
- IPRINT2 toggle on (1) or off (0) state.
- iscal
- ISCAL value.
- iscaltoggle
- ISCAL toggle on (1) or off (0) state.
- itmax
- ITMAX value.
- itmaxtoggle
- ITMAX toggle on (1) or off (0) state.
- itrmop
- ITRMOP value.
- itrmoptoggle
- ITRMOP toggle on (1) or off (0) state.
- itrmst
- ITRMST value.
- itrmsttoggle
- ITRMST toggle on (1) or off (0) state.
- jprint
- JPRINT value.
- jprinttoggle
- JPRINT toggle on (1) or off (0) state.
- jtmax
- JTMAX value.
- jtmaxtoggle
- JTMAX toggle on (1) or off (0) state.
- jwrite
- JWRITE value.
- jwritetoggle
- JWRITE toggle on (1) or off (0) state.
- manthr
- MANTHR value.
- manthrtoggle
- MANTHR toggle on (1) or off (0) state.
- method
- METHOD value.
- methodtoggle
- METHOD toggle on (1) or off (0) state.
- nas_desmax
- DESMAX value.
- nas_desmaxtoggle
- optimomp
- OPTIMOMP value.
- optimomptoggle
- OPTIMOMP toggle on (1) or off (0) state.
- p1
- P1 value.
- p1toggle
- P1 toggle on (1) or off (0) state.
- p2
- P2 value.
- p2oggle
- P2 toggle on (1) or off (0) state.
- ptol
- PTOL value.
- ptoltoggle
- PTOL toggle on (1) or off (0) state.
- solverkeyword
- stpscl
- STPSCL value.
- stpscltoggle
- STPSCL toggle on (1) or off (0) state.
Version History
2017.2 - Added new data names contol, contoltoggle, restart, restarttoggle, topdisc, topdisctoggle, topdv and topdvtoggle.
2019 - Added new data names manthr and manthrtoggle.
2020.1 - Added new data name solverkeyword.
2021 - Added new data names optimomp and optimomptoggle.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022.1 - Added new data names almtostr and almtostrtoggle.
