membersections
Unless otherwise specified, data names are accessible in level 3 only.
_baseFlags
The base flag of the entity.
Type: unsigned integer
_representations
The representations of the entity.
Type: entity array
_representations_functionalrepresentation
The functional representations of the entity.
Type: entity array
_representations_geometricrepresentation
The geometric representations of the entity.
Type: entity array
_representations_solverrepresentation
The solver representations of the entity.
Type: entity array
_subType
The sub type of the entity.
Type: string
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
autoweld
Flag to perform auto weld on the realized beam section of the member section.
Type: Boolean
auto_detect_thin_solids
Flag to detect thin solids for the realized beam section of the member section. This flag works only if the intersectingentitytype data name is set to solids (55).
Type: Boolean
beamsection
The beamsection ID associated with the member section.
collectioncentroid
The centroid of the collection of intersecting entities of the member section.
Type: triple double
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
computeintersections
The flag that computes intersecting entities from the parameters of the member section.
Type: Boolean
config
The configuration of the entity.
1 – Dependent
2 - Independent
corner1
The location of the first corner of the face of the member section.
Type: triple double
corner2
The location of the second corner of the face of the member section.
Type: triple double
corner3
The location of the third corner of the face of the member section.
Type: triple double
corner4
The location of the fourth corner of the face of the member section.
Type: triple double
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
excludedentities
The list of entities that should be excluded from the face of the member section.
Type: unsigned integer array
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
intersectingentities
The list of entities intersecting the face of the member section.
The type of entity representing the intersection.
intersectioncords
The list of points at which the entities have been intersecting the face of member section.
Type: triple double array
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
orientationvector
The orientation vector of the beam section associated with the member section.
Type: triple double
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
parentsection
The ID of the parent member section.
planebase
The location of the face plane of the member section.
Type: triple double
planenormal
The normal of the face plane of the member section.
Type: triple double
planeshape
The shape of the plane associated with the member section.
1 - Rectangle
2 - Square
3 - Circle
planetype
The type of plane associated with the member section.
1 - Infinite plane
2 - Finite plane
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
radius
The radius of the circle defining the member section.
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
symmetryid
The ID of the symmetry plane.
Type: entity
Version History
2022
2022.1 - Added new data names autoweld and auto_detect_thin_solids.
