handles
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- bias
- The bias factor of the handle.
- definedentity
- True if the entity is defined, false otherwise.
- grid
- The ID of the node the handle is located at.
- handleids
- Pointer to the handles the handle is dependent on.
- handleidsmax
- The number of handles the handle is dependent on.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- infg
- Pointer to the node influences.
- infhn
- Pointer to the handle influences.
- internalid
- internalname
- The internal name of the entity.
- level
- The handle level.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- ninfs
- The number of surface points the handle influences.
- nodeids
- Pointer to the nodes the handle influences.
- nodeidsmax
- The number of nodes the handle influences.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- sym
- Pointer to the symmetries associated with the handle.
- symids
- The IDs of the handles linked to the handle for a given symmetry.
- symidsmax
- symidsmax The number of handles linked to the handle for a given symmetry.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
