panels
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - Entitylist
 - The elements contained in the panel.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - length
 - The length of the panel.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - OuterElems
 - The outermost elements in the panel.
 - OuterNodes
 - The outermost nodes in the panel.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - radius
 - The radius of the panel.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - width
 - The width of the panel.
Version History
2017.1
2020 - Added new data names color_rgb, length, radius and width.
2020.1 - Added new data name solverkeyword.
2021.2 - Added new data names internalname and solvername.
