sequences
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- datalines
- The number of layers for config 2.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalname
- The internal name of the entity.
- integrationpoints
- The list of integration points for each of the ply IDs for config 2.
- internalid
- materials
- The list of materials for each of the ply IDs for config 2.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- orientations
- The list of orientations for each of the ply IDs for config 2.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- plyids
- The list of ply IDs for config 2.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- resultrequests
- The list of result request options for each of the ply IDs for config 2.
- shape
- The list of elements which define the shape of the zone for config 2.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- thicknesses
- The list of thicknesses for each of the ply IDs for config 2.
Version History
2020.1
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
