attachmentcontrols
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- connectouterlayer
- The way to connect to the hole for config 1.
- createelements
- True if an element set is created, false if a node set is created.
- definedentity
- True if the entity is defined, false otherwise.
- duplicateelems
- True if a projection element is duplicated, false if the original projection element is used.
- elemtype
- The element type name for config 1.
- engname
- The engineering name.
- feature
- The attachment feature for config 2. Valid values are Hole and Projection.
- holeandwasher
- The option to fill hole or use washer elements for config 2.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- maxdia
- The maximum diameter for finding a hole when findhole is 1.
- maxlayers
- The number of layers to create projection attachment for config 2.
- mindia
- The minimum diameter for finding a hole when findhole is 1.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2020
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names createelements, duplicateelems, feature, and maxlayers. Removed data name findhole.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
